Show whether an object can be shared to a Project?
Is there a way to show whether a file can be shared to a Project or not BEFORE it's shared? For example, on the structure tab of an assembly if there were to be a column view with a "yes you individual user can share this" or "you don't have permission to share this file"... Any thoughts on whether this can be set up?
