SQL query to retrieve WTParts for given OR condition between 2 IBAs
HI all,
Can anyone please help me in optimizing the SQL query
. I have written a sql query to retrieve WTParts when 2 IBAs are given . (using OR, AND conditions).
SELECT A0.* FROM WTPart A0,UnitValue A1,StringValue A2,WTPARTMASTER A3 WHERE (A0.ida3masterreference=A3.ida2a2 and A3.WTPartNumber LIKE 'RT-3294%') AND (((A1.idA3A6 = 3853762) AND (A1.value = 0.037099) AND (A1.idA3A4 = A0.idA2A2)) OR ((A2.idA3A6 = 19907282) AND (A2.value = '22') AND (A2.idA3A4 = A0.idA2A2))) AND (A0.idA3view = 569) AND (A0.latestiterationInfo = 1) AND (A0.variation2 IS NULL ) AND (A0.statecheckoutInfo <> 'wrk').
But when this query is executed , its generating only 1 part more than 10k times . May I know if I have to modify the query.
Thanks.
hlafkirAnswer
Please add (add logger article) the logger wt.pom.sql  (logger article link)in a test environement and create a search in Windchill UI.
This logger will generate the right sql query into your method Server and help you to create the request sql syntax.
For an IBA not null in my environement I could get :
SELECT A0.*,A1.idA2A2,A1.updateCountA2,A1.idA3A6,A1.value,A1.value2
FROM WTPart A0,StringValue A1 WHERE (((A1.idA3A6 = 138794) AND (A1.idA3A4 = A0.idA2A2) AND ((A1.idA3A5 = 0) OR (A1.idA3A5 IS NULL )))) ;
and it is returning the expected results.
Hicham
hlafkir5-Regular MemberAnswer
Hicham
gmydoor-210-MarbleAuthor
Thanks a lot . I will check and revert.
