Text entry box sizes on Change Task Activities
  • July 20, 2023
  • 6 replies
  • 2249 views
Can the boxes of parameters that are resettable for an Change Task Activity be enlarged?2023-07-20_10-21-44.jpg
jbailey
18-Opal
July 20, 2023
Try this: ( I used document type)
Input field type for the attribute has to be Multiple Lines
Go to actions > Edit on the type, then click layouts, the attribute, then the pencil above the attribute
Edit number of columns and number of rows
 @jbailey these are not part of the layout, but are part of the task that are defined here as visible.
jbailey
18-Opal
July 20, 2023
Hm, I figured you could do it with one of the layouts under work item, since the task completion is a work item 😐
I just used document since I already had some multi-line attributes there
