6-Contributor
the addition, deletion and modification of classification nodes and classification node attributes
In Windchill 11.0 M030 version, since it is necessary to receive from other systems through interfaces, sample code related to the addition, deletion and modification of classification nodes and classification node attributes is required. After checking, I learned that in Windchill11.0 version, there is no supported API for direct operation.
Catalina
Community Manager
Hi @铭周_10045792
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Could you clarify what you're hoping to achieve or understand in this case?
  • Are you trying to automate classification node changes via external system integration (e.g., using Info*Engine or REST)?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
Fadel
23-Emerald II
The supported Apis are available starting 12.0 , see https://www.ptc.com/en/support/article/CS338403
Buiꓘa
