The CAD Publishing rule wat we have defined is not working in the UAT instance
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.1
The CAD Publishing rule wat we have defined is not working in the UAT instance (which is an cluster instance ) but the same CAD Publishing rule is working in the lower instance .
    Catalina
    Community Manager
    Hi @SA_10753387
    Thank you for your question!
    I’d like to recommend to bring more details and context to your initial inquiry. For example:
    • Are both the UAT and lower instances using the exact same publishing rule configuration?
    • Is the CAD worker properly configured and running in the UAT cluster?
    • Are there any differences in file vaulting, replication, or queue management between the two instances?
    Please add screenshot(s) to better understand what you are trying to do in your process.
    Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
    Here's what a good question for Creo looks like.
    Thank you for your participation and please let me know if you need further assistance!
    Best regards,
    Catalina | PTC Community Manager
