ozclkonur
Timeout Issues with Windchill REST APIs When Method Server is Not in Full Screen
I developed an application in C# that retrieves information through a REST API from attachments, references, WTUser, and representations based on the EPMDocument idA2A2, except for WTUser. Later, I started encountering timeout issues with these APIs. The interesting thing is that when I switch the method server console to full screen, the timeout problem disappears, and this only happens with the APIs I mentioned. There are no issues with connections like WTPart. Is the reason for this that I am trying to process these APIs consecutively, or is there an issue with a setting related to EPMDocument in Windchill? Because, as I said, when I make the method server full screen, the timeout problem goes away. Should I try restarting the server?
Catalina
Community Manager
Hi @ozclkonur
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
HelesicPetr
Hi @ozclkonur
What do you mean Method server full screen? Do you talk about command line utility CMD where the method server is run?
If so, be sure that you did not pause the process by selecting a line or char in the command line window.
PetrH
