To fetch affected objects for Variance
  • March 22, 2017
  • 3 replies
  • 1694 views
I want to fetch the Affected Objects for the type Variance in a workflow.
My doubt how to fetch all the objects added to affected objects of Variance? Suggestions/APIs please.
ShirishMorkhade
Hi Anjali Sharma,
You may like to try below code snippet:
public class AffectedObjectsVariance {
  public static void main(String[] args) throws ObjectNoLongerExistsException, WTException {
       ObjectIdentifier eoid = ObjectIdentifier.newObjectIdentifier("wt.change2.WTVariance:2336782");
       WTVariance var = (WTVariance)PersistenceHelper.manager.refresh(eoid);
       System.out.println("Variance Name >> " + var.getName());
       QueryResult qr = ChangeHelper2.service.getChangeables(var);
       System.out.println("Total Objects in Variance >> " + qr.size());
       while (qr.hasMoreElements()) {
            WTPart prt = (WTPart) qr.nextElement();
            System.out.println("Part Name >> " + prt.getNumber());
I hope this helps you!
Shirish
ash1-VisitorAuthor
It worked. Thanks.
