Two data utility for an attribute
can we have two Data Utility functions for the same attribute(datautility for making attribute multivalued and Picker datautiliy)?
HelesicPetr
Hi @DJ_10206604
I don't think so that you could mix two dataultity separately that way as you think..
You would need to find a way how to achieve what you need with multivalue attribute in one datautility.
That's just my thoughts
I've never tried it.
PetrH
11-Garnet
October 18, 2022
Hi @DJ_10206604,
One attribute cannot be registered with two Datautilites.
Try to remove single valued constraint on attribute and register it with Datautility.
So, in that way it will be multi valued and picker.
Hope it works.
HelesicPetr
Hi @TT_9345405
Good point to remove the constraint.
Additionally you need to process multivalued string in the data-utility.
The values are usually separated by "@" I guess.
PetrH
