Unable to create As Stored BOM in Windchill (Using EPM MemberLink Relaiton - InfoEngine API)
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.0
Here are the errors that I faced
Latest Revision of the child EPM Document shows up even when the specific revision is passed at the child level in the BOM.
    18-Opal
    Hi @RG_13245189,
    Why do you want to create an As-Stored BOM through the API?
    Which API are you using for this?
    Could you please share the MS logs?
    HelesicPetr
    Hi @RG_13245189
    There is a helper to create As Stored Config.
    EPMAsStoredHelper.createEPMAsStoredConfig(Collection var0, ConfigSpec var1, boolean var2)
     OptionsOptions
    PetrH
