Unable to retreive the input tex box values from previous step of a wizard, in the current step having a table builder
We have a requirement for mass change quantity update, where we have 2 input text boxes in step 1 and in step 2 we have a table builder. The data on the table builder in step 2 would be based on the text box input from step1, but i am not able to get the value of the text box from step1 in the Nmcommand bean of the table builder. Could you please assist me here?
TDTAnswer
18-Opal
Hi ​@AC_14555549,
You may need to refer to the following article.
https://www.ptc.com/en/support/article/CS358817?source=search
TDT18-OpalAnswer
18-Opal
Hi ​@AC_14555549,
This article is not applicable. As my wizard has table builder
By updating the jsp with the above suggested changes and in addition only using generic jsp tags instead of the jca tags, resolved the issue. Thanks.
3-Newcomer
You can use javascript to get step 1 value
Community Moderator
Hi ​@AC_14555549,
Anurag
