Unable to Update Upper Limit of NAME Attribute on WTPart – Error During Ant Script Execution
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.0
We are trying to update the upper length limit of the NAME attribute on WTPart, following the steps described in article CS155068. When we run the Ant script (ant -f bin\tools.xml custom_column -Dgen.input=wt.part), we receive the following error in the Shell: java.lang.NoClassDefFoundError: org/apache/commons/lang3/exception/ExceptionUtils
Here are the errors that I faced
ava] Processing single class: wnc/Foundation:wt.part.WTPartMaster
[java] DataStore = SQLServer
[java] wt.generation.sql.useDatastore = false
[java] wt.generation.sql.loadIntrospectionFromClasspath= true
[java] wt.db.maxBytesPerChar = 1
[java] InsternalUsage = false
[java] Begin sql generation for wt.part.WTPartMaster
[java] 15:23:16.508 [main] ERROR wt.util.AppStarter - ERROR: details below
[java] ERROR: java.lang.NoClassDefFoundError: org/apache/commons/lang3/exception/ExceptionUtils (check log for details: D:\ptc\Windchill_13.0\Windchill\buildlogs\tools-CustomizeColumnLength.log)
[java] 15:23:16.521 [main] ERROR wt.util.AppStarter -
[java] java.lang.NoClassDefFoundError: org/apache/commons/lang3/exception/ExceptionUtils
[java] at com.ptc.commons.lang.util.exception.ExceptionUtils.getStackTrace(ExceptionUtils.java:21) ~[codebase/:?]
[java] at wt.tools.SqlGenerator.processModuleQualifiedTarget(SqlGenerator.java:152) ~[SystemGeneration.jar:?]
[java] at wt.tools.SqlGenerator.processClass(SqlGenerator.java:101) ~[SystemGeneration.jar:?]
[java] at wt.tools.generation.ModelProcessor.execute(ModelProcessor.java:89) ~[SystemGeneration.jar:?]
[java] at wt.tools.SqlGenerator.execute(SqlGenerator.java:57) ~[SystemGeneration.jar:?]
[java] at wt.tools.CustomizeColumnLength.sqlGen(CustomizeColumnLength.java:218) ~[SystemGeneration.jar:?]
[java] at wt.tools.CustomizeColumnLength.execute(CustomizeColumnLength.java:83) ~[SystemGeneration.jar:?]
[java] at wt.util.AppStarter.startAppWithCurrentClassLoader(AppStarter.java:287) ~[codebase/:?]
[java] at wt.util.AppStarter.startApp(AppStarter.java:150) [codebase/:?]
[java] at wt.util.AppStarter.main(AppStarter.java:479) [codebase/:?]
[java] Caused by: java.lang.ClassNotFoundException: org.apache.commons.lang3.exception.ExceptionUtils
[java] at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641) ~[?:?]
[java] at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188) ~[?:?]
[java] at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525) ~[?:?]
[java] ... 10 more
!+! ERROR OCCURRED @ D:\ptc\Windchill_13.0\Windchill\bin\tools.xml:1478: !!!
    jbraga
    The commons-lang3.jar library should be contained in the Windchill/srclib directory. This JAR is incorporated into Windchill/codebase/WEB-INF/lib/wc3rdpartylibs.jar by the command in article CS378840 under Windchill/srclib: ant -f windchill3rdPartyJars.xml wcjars
    Catalina
    Community Manager
    Hi @PS_11312577 ,
    If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
    Catalina | PTC Community Manager
