Update Product templates by loadfromfile.
How can update Product container Templates by Load from file without using Windchill UI?
any Windchill shell query? or DB query?
Emeritus
Hi AS_10279084
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
avillanueva
23-Emerald II
Any reason? Its very easy to do in the UI. Why would you want the complexity of loading via shell? Say you configure a product the way you like it. You can save as a template easily, download the file, edit it and reupload it back to the template with your mods. Easier than via shell.
HelesicPetr
Hi @avillanueva
I can see some cases.
1. Configure testing system without cloning production
2. Move configuration from test system to production by automatization
Iam sure that there can be some loadfromfile option to do so.
You need to go  to Windchill\loadFiles and Windchill\loadXMLFiles and search for an OOTB product template and search for the xml where is the load defined for loadfromfile.
PetrH
