Aug 31, 2023 12:41 PM UTC
Usage of remoteMethodServer.invoke and RemoteMethodServer.ServerFlag
Hello community!
I am looking through the PTC | Windchill code right now and I am encountering a lot of if(RemoteMethodServer.ServerFlag) { run code } else { remoteMethodServer.invoke(...)} constructs.
I am figuring this means something like "If the code is executed server-side then continue, otherwise invoke the method on the particular method server". But where would this code be executed, if not on the method server?
Can anyone please give me a better / more technical explanation. Why is it important to use this construct and when should you use it?
Thanks in advance and best regards
HelesicPetr
Aug 31, 2023 12:54 PM UTC
Hi @TG_10272716
The code can be run from Windchill shell, that moment you should care what MS you want to use or you can get the default one.
If method server is not available then code fails
PetrH
HelesicPetr
Hi @TG_10272716
PetrH
Sep 6, 2023 10:04 AM UTC
Hi @HelesicPetr, thank you for your reply. So, this basically means that I have to implement some kind of check (like mentioned above) whenever the code can or might be executed in the Windchill Shell.
Are there any other cases where this is required, what about Queues? Isn't there a difference between executed by Windchill (scheduled queue) and executed by the user (click)?
Best regards
HelesicPetr
Sep 6, 2023 11:04 AM UTC
Hi @TG_10272716
I would say yes .
queue is run on the method/background server directly so you do not need to cares about the check
PetrH
