Oct 5, 2021 5:00 AM UTC
Usage values coming twice in ESI Response file
I have a custom usage attribute defined which is supposed to be coming only once in the ESI response file, but if there is a change in usage values like Quantity, the custom usage attribute tag is coming twice in the response xml with the same values. Please let me know if any of you have faced this issue.
Sha
