avillanueva
23-Emerald II
September 13, 2023
Use of WVS Scheduler Administrator for non-WVS related tasks
I cannot see why not but let me know if anyone has used the WVS Scheduler Administrator for other administrative tasks other than publishing and WVS. I have a sync task were I need to connect to an outside database and compare data to objects in Windchill. Seems to be the perfect vehicle to create the jobs, schedule it and monitor its execution. Assuming other scheduler tasks are defined in a similar manner, is there a more recommended method of hooking them in or kicking them off?
d_grahamAnswer
18-Opal
September 14, 2023
@avillanueva I hear you loud and clear.
The way I do this is by writing and class that I run from a Windchill shell.
The class creates a queue entry that is scheduled to run at a pre-determined time.  When that time comes the class runs and does whatever it was designed to do.  The very last thing the class does before completing is it creates another queue entry to run at the next pre-determined time, and so on.
Using this technique, I have full control over the execution time and frequency.
So, you could do this to connect to the external dB and run the code that compares the dB tables and columns.
HelesicPetr
Hi @avillanueva
Good idea but for some new staff it can be confusing if WWS Scheduler can do different work.
I like your idea.
I usually create own page, where I control custom tasks that I send to custom queue.
For example delete utility for visualization 😄
PetrH
avillanueva
23-Emerald II
September 14, 2023
At one point I saw a way to kick off a scheduler job via command line. I guess your UI and the WVS schedule are doing the same thing. Your UI seems dedicated to that visualization delete job.  What's needed is something exactly like the WVS scheduler but where you can control the execution time, frequency, job type and possibly the queue it runs in.
d_graham18-OpalAnswer
18-Opal
September 14, 2023
