Wanted to change bulk "Change Task Template" to new sub type
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.0
Hi PTC Team,
We want the change all the change Task template to different Change Task Sub Type, is there any API or code do we have to convert the Sub Type?
    HelesicPetr
    Hi @AK_12943638
    You have to do it manually, There is no API that support the template type change.
    1. Create new template as a subtype of a change task.
    2. Disable the root template.
    Also you can check an existing tool.
    There is a utility that can be used to change a object type but, it works just for all objects of the type.
    CS368420 - How to change type of existing objects with "ChangeTypeSql" utility in Windchill
    Change the Type of the Existing Objects in Windchill PDMLink
    PetrH
    Community Moderator
    April 3, 2025
    Hello @AK_12943638,
    It looks like you have a response from our community champion. If it helped to answer your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
