18-Opal
Feb 26, 2024 6:10 AM UTC
What is the use of publish.markoutofdate.traversal.precheck.filtermethod
What is the use publish.markoutofdate.traversal.precheck.filtermethod property and when it triggers actually?
TDTAnswer
18-Opal
Mar 8, 2024 9:54 AM UTC
The publish.markoutofdate.traversal.precheck.filtermethod is used to stop the traverse of structure upwards before the MOOD happens.
We can customize with our custom class to stop the parent assembly becoming from MOOD with some conditions.
Emeritus
Feb 29, 2024 6:23 AM UTC
Hi TDT,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
HelesicPetr
Feb 29, 2024 10:51 AM UTC
Hi @vnamboodheri
I would ask PTC Support directly because there is no documentation for the mentioned properties.
Obviously no active community member has an experience with this precheck.filtermethod properties.
PetrH
TDT18-OpalAuthorAnswer
18-Opal
