Where I can get the documentation on Windchill with detailed examples
Hello, please tell me where I can get the documentation on Windchill with detailed examples of working with the code, because in the usual documentation 99% of the information is not clear to me at all, even the first examples do not turn out?
VladimirNAnswer
Hi Vladislav,
What type of an example you are interesting (Windchill UI , business logic...)?
What technology Java, jsp, REST, webject, Angular...?
Did you read Windchill CustomizerGuide?
VladiSlav17-PeridotAuthor
Hi,  Ivan , I tried to run the example from the cust_Windchill_src documentation https://support.ptc.com/help/wnc/r11.2.0.0/en/#page/Windchill_Help_Center%2FWCCG_Oview_GetStartCust_CreatePetClass.html%23 , but for me it was not clear, since java I had recently started to learn, and eclipse had not used before. And so I want try any more understandable and detailed examples, to basic skills obtain
There is no beginner guide for Windchill programming, but if you are good with Java there is no any issue with Windchill Java programming. You can read and practice with this perfect Java book Thinking in Java (4th Edition): Bruce Eckel, I did this 15 years ago with 3rd edition.
VladimirN24-Ruby IVAnswer
The following links may be helpful:
"PTC Learning Connector": https://learningconnector.ptc.com/products/windchill/all?contentLocale=en&version=all
"PTC Help Center": https://www.ptc.com/en/support/help/Windchill
"Reference Documents": https://www.ptc.com/en/support/refdoc
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
