Apr 16, 2024 11:46 AM UTC
Windchill API to iterate
I have to create a new epmdocument or new wtdocument with following versions in sequence using API code.
object1.asm - M.1, M.3,M.9
My ask is, after creation of M.1, how can i create M.3 with out M.2.
If i do check-out & check-in (through code), it will create M.2 which i dont want.
Please help me. Thanks in advance.
HelesicPetr
Apr 16, 2024 1:07 PM UTC
Hi @NP_10570407
Why do you want to keep an iteration history? I don't see any good reason for it.
System is not designed to jump over iterations so keep the system behavior. Create all iterations or create the last one.
PetrH
Apr 17, 2024 1:38 PM UTC
This is a possibility in Data Migration scenarios.
18-Opal
Apr 17, 2024 11:14 PM UTC
Why don’t you explain in detail what you are trying to do rather than just saying to want to skip an iteration number.
I’m sure it’s doable, most things are.
tarik_perc
May 18, 2024 11:44 PM UTC
You can checkout twice 🙂 if your use case is that simple !
I agree with @HelesicPetr that cannot skip or jump the next iteration, from UI functionalities, let alone from code, isn’t it ? Which is different with revisions.
May 20, 2024 6:25 AM UTC
Instead of creating M.1, you can directly create to M.3, if you are loading data with specific version and iteration, that's doable
