Windchill ESI - WTPart Publish through Code
We have a requirement to send certain WTPart data from Windchill to ERP using ESI, specifically for parts that are created on a given day.
The idea is to pick up all parts created on that day (they will still be in an unreleased state) and send them to ESI so that the XML gets generated. Later, once the parts go through the normal change/release process, the updated data will be published again.
My plan is to write a custom piece of code that runs on a schedule (maybe a nightly job). It would:
  • Query all WTParts created on that day
  • Loop through them
  • Send them to ESI programmatically
Before going ahead, I wanted to check if anyone has already done something similar — mainly:
  • Triggering ESI publish via code (instead of using the UI “Send to Distribution Target”)
  • Generating ESI XML for parts using this approach
Any pointers on the recommended API or approach would be helpful.
18-Opal
Hi ​@Srinivas_256,
I would suggest implementing a check to determine when the scheduler last executed and then retrieving only the parts created after that point in time.
This approach is preferable because scheduler execution times can vary from day to day depending on system load and the number of scheduled tasks. As a result, the job may not always run at the exact scheduled time.
Regarding the API for publishing objects, please refer to the following article.
https://www.ptc.com/en/support/article/CS318762?source=search
