Feb 3, 2017 10:56 AM UTC
Windchill header: show dynamic message
Hi everybody,
I am here suggesting to create a preference at site level, where the administrator can type a messsage to show on the header, near the logo.
This would be mainly used to advise users about maintenance (Example: "Server will be shutdown from 9pm-11pm") or other short messages.
Riccardo
Feb 8, 2017 10:25 PM UTC
‌Does editing the existing banner.txt feature work for you? Seem pretty close to what you're asking for: http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=WCCG_UICust_GenericUICust_SysBannerAlert&action=show
Feb 9, 2017 9:56 AM UTC
Hi Hansen,
not completly because in that case we need to restart the server and this is exactly what I do not want to do: I need first to show the message, and later restart the server (usually the day after).
I can send an e-mail to all the recipients but they should still keep in mind at what time the server will be restarted.
20-Turquoise
Feb 9, 2017 2:23 PM UTC
Riccardo Vecchiato wrote:
Hi Hansen,
Actually you don't need to restart it again once you have made the changes in this article:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS77184
Feb 9, 2017 5:07 PM UTC
Do you mean that the file is not cached and if I modify the text it is automatically retrieved and shown?
As far as I understand following that method I can show a custom message, but my need is to show a different message without restarting the server, for example:
Customize the banner without any message (OK, based on your suggestion)
Restart the server (obviously, otherwise the new file is not read)
Write a new message in the customized file (OK, based on your suggestion)
See the new message in the Windchill header without any restart (I am not sure your suggestion will work)
Feb 9, 2017 6:42 PM UTC
‌Yes, as far as I can remember `banner.txt` is not cached. Try it and see!
Otherwise the link to the CS given by Randy Jones‌ above has a more complete description that also handles different browser locales. I think we are using that as well.
20-Turquoise
Feb 9, 2017 8:52 PM UTC
Yep. Now if the user is setting on a Windchill page, when you change banner.txt, then they will need to reload (using the browser Reload current page) the Windchill web page in order to see the changed message in their browser.
Feb 10, 2017 9:25 AM UTC
Thank you very much! It's working as expected and it is not cached! 🙂
