8-Gravel
November 23, 2024
windchill REST API
  • November 23, 2024
  • 3 replies
  • 709 views
Can you please describe the steps to run Windchill REST API with Power BI.
OlcaytoK
7-Bedrock
November 24, 2024
Hello SaurabhSingh,
As far I know the many people using directly from SQL, may you can use Windchill reports  as SQL Query.
You can check below link for details.
https://support.ptc.com/help/windchill/plus/r12.0.2.0/en/index.html#page/Windchill_Help_Center%2FQBTools.html%23
PTC does not recommend or support directly accessing the Physical data model (representation in the data base) and expects customers to access the Logical data model (representation in Windchill services) for
  • Access control
  • Logical link navigation
  • Support & Help
  • Upgradeability
  • License compliance
Where possible, please use WRS to access Windchill data from outside of Windchill.
Community Moderator
November 28, 2024
Hello @SaurabhSingh,
Thank you for using PTC Community!
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
