Windchill workflow customization
Is it possible to complete a workflow task programmatically using Java code?
For example, I would like to complete a Change Notice task programmatically rather than through the user interface. Is this supported? If so, could you please provide some guidance on how this can be achieved?
Best Regards,
Shrikant Bhosle
SummerAnswer
​@Shrikant Bhosle
Sample code:
                   WorkItem workItem = (WorkItem) persistable;
                    WTPrincipalReference user;
                    String routId;
                    WfActivity wfActivity = (WfActivity) workItem.getSource().getObject();
                    WfProcess wfProcess = wfActivity.getParentProcess();
                    // check activity if complete.
                    if (!workItem.isComplete()) {
                        // complete workitem
                        String comments = "";
                        List<String> eventList = new ArrayList<String>();
                        eventList.add(routId);
                        WorkflowHelper.service.workComplete(workItem, user, CollectionUtil.toVector(eventList));
                        WfEventHelper.createVotingEvent(null, wfActivity, workItem, user, comments,CollectionUtil.toVector(eventList),false, workItem.isRequired());
                        wfProcess = (WfProcess) PersistenceHelper.manager.refresh(wfProcess);
18-Opal
Hi ​@Shrikant Bhosle ,
What is the business use case for this requirement?
18-Opal
Hi ​@Shrikant Bhosle,
Please refer to the API below.
		WorkflowHelper.service.completeActivity(wfActivity, wfProcess, string, principalReference, string);
Summer16-PearlAnswer
​@Shrikant Bhosle
Sample code:
                    String routId;
