WizardStep Not Closing After Validator DENIED
Version: Windchill 12.1
Use Case: Open a Windchill folder and click 【Export List to CSV】.
The exportTable.jsp wizard opens with a wizardStep
Add a custom validator before the standard export processing:
return UIValidationResult.newInstance(var1, UIValidationStatus.DENIED, UIValidationFeedbackMsg.newInstance( "Error message", FeedbackType.ERROR));
The validation message displays correctly in the wizardStep popup.
Click OK on the message dialog.
Expected Result: After acknowledging the validation message, the wizardStep popup should close safely without JavaScript errors.
Description:
When adding a custom validator to Windchill’s standard “Export List to CSV” action,
the validation message displays correctly in the wizardStep popup.
However, after clicking OK in the message dialog,
the wizard does not close properly. The browser console logs the following JavaScript error
windchill-all.js:1556 Uncaught TypeError: top.finishServerSideExport is not a function
 at PTC.exportTable.exportTableSuccessListener (windchill-all.js:1556:281)
 at handleSubmitResult (windchill-all.js:3759:62)
 at handleSubmitResult (windchill-all.js:2317:91)
 at ext-and-extensions.js:1845:156
HelesicPetr
Hello @福耿_13361195
In my opinion this is standard behavior, if there is an error after you click the OK.
The error message informs a user that there is something wrong there and user has a option to correct the wizard input.
So there for the wizard is not closed.
If you need to change this behavior, you have to add a FormResult - setNextAction or find a way how to do so in wch 13.1+ because some methods are deprecated
PetrH
Catalina
Community Manager
Hi @福耿_13361195
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
HelesicPetr
Hello @福耿_13361195
PetrH
Thank you for your explanation.
I understand that keeping the Wizard open after validation fails is the standard behavior, so that users can correct their input.
However, in my case, I would like to close the Wizard even when my custom Validator returns DENIED.
I'm using the standard CSV export functionality, so I cannot easily customize or replace its FormProcessor.
Is there any way to achieve this behavior in Windchill 13.1+ without customizing the standard FormProcessor?
You mentioned using FormResult.setNextAction(). Could you please provide an example of how this could be implemented in this scenario?
Thank you for your help.
