Mar 14, 2018 10:24 PM UTC
Workflow expression code - Dialog box for user input
I'm looking for a workflow expression code that will launch a dialog box for the reviewer to select an item from a drop-down list when rejecting. The goal is to append the selected value to the Comments and write it into the database to later extract and report on workflow rejections.
I tried using the Java Swing Dialog, but am stuck with an error...
Here's the sample code (2nd line throwing error):
String[] codes = {"DES", "DFT", "BOM"};
String code = (String) javax.swing.JOptionPane.showInputDialog(null, "Select Rejection Code:", "You have chosen to reject this workflow:", javax.swing.JOptionPane.QUESTION_MESSAGE, null, codes, codes[1]);
if (code.trim().length() == 0) {
throw new wt.workflow.engine.FailedTransitionException(e2);
The error is:
wt.util.WTException: java.awt.HeadlessException
Does anyone know a way around the above error, or have an alternative method of launching a dialog box from a workflow expression?
Thank you!
20-Turquoise
Mar 15, 2018 2:27 PM UTC
The error is:
Thank you!
Workflow java code runs on the server not on the client. The "java.awt.HeadlessException" means "I have no display to connect to".
You will need to create a workflow or task variable and have the user select this on the task page. You can have code that checks to make sure the user selected something if Rejected.
daraki1-VisitorAuthor
Mar 15, 2018 3:40 PM UTC
Thanks for the reply. I see that makes sense... Would setting this property "java.awt.headless" to false on the server resolve this? I did come across CS36017 that outlines how to create a drop-down menu on the workflow task form, but it requires Windchill Information Modeler which we don't have. Is this the method you suggest?
