Workflow task page Windchill 10.2 vs 11
- 2 replies
- 3449 views
- Translate All
In Windchill 10.2 the Subject (PBO) is above the Instructions section. In Windchill 11.0 the Subject (PBO) is below the deadline. We would like to move it back up to above the Instructions. I'm trying to figure out what is controlling the configuation. Our workflow tasks are set to use JPS (Default). I have found another post indicated that if the workflow task activity is set to use JPS the Task Info Page Layout from the Work Item object in the Type and Attribute Management is used. When I look at the Task Info Page Layout, the Subject is in the correct locations. I have also looked at the Task From Templates (default JSP), but I don't have an JSP editor to test moving the Subject (PBO). I have also opened a call with PTC, but they told me I would have to talk to the customization team. I have attached some screen shots.
