WQS Table Find and Replace Order of Operations under Filtered Condition
- 0 replies
- 1461 views
- Translate All
Please read the attachment to see example.
WQS Table Find and Replace Problem:
The Find and Replace feature seems to only search records that fall under the selected filter. Once the record condition changes it immediately excludes those from the search.
Users are finding this a pain when they are using the Find and replace feature. If they accidental replace the wrong group of data fields assuming that this field is associated to the field included in the current filter can make it a hassle to correct these changes.
There should be a way to allow the find replace feature to work on all datafields currently present in the table regardless on the change to filtered conditions. I was told that when using excel this feature works in this order of operations.
In the example below.
I filtered the deleted datafield by checked boxes only. Then I removed three of the check boxes. Now I tried to Find search for the (xx) value which is in one of the changed records that is still present. The result dose not find it. I try other value in the three unselected records.
Results:
See attachment
