6-Contributor
Jun 29, 2023 3:31 PM UTC
WTPartUsage link creation using API
How to create WtPartUsageLink in windchill 11. 1 through API. I am looking for one Sample.
20-Turquoise
Jun 29, 2023 9:53 PM UTC
// work in process parent
// WorkInProgressHelper.service.checkout
WTPart parent;
WTPart component;
// create a Quantity
Quantity qty = new Quantity();
qty.setAmount(1);
qty.setUnit(QuantityUnit.EA);
// create the usagelink
WTPartUsageLink usageLink = WTPartUsageLink.newWTPartUsageLink(parent, component.getMaster());
// set the usagelink quantity
usageLink.setQuantity(qty);
// persist the usagelink
usageLink = (WTPartUsageLink) PersistenceHelper.manager.save(usageLink);
20-Turquoise
WTPart parent;
WTPart component;
qty.setAmount(1);
Mar 8, 2025 12:30 AM UTC
I'm having a problem with this. I am able to successfully add the child to the parent using this code, but later if I delete the parent and then try to checkout the child in the UI, it fails. I get a message saying the deleted parent is "deleted or inaccessible". The wtpartusagelink isn't cleaned up in the db when I delete the parent part. It still refers to the deleted part. Can you test this?
20-Turquoise
Mar 10, 2025 6:34 PM UTC
Works for me. You did not specify how you deleted the parent. I deleted the parent thru the UI.
Windchill 13.0.2.2
