WVS AfterLoader
  • July 6, 2020
  • 10 replies
  • 4877 views
Hello folks,
I'm trying to get the AfterLoader set up...  when following the instructions for running the following
javac -classpath %CLASSPATH%;%WT_HOME%\srclib\tool\Annotations.jar -d %wt_home%\codebase AfterEDRloader.java
i get a invalid flag error... I'm a touch new... I don't think there are environment variables set on my install.  What would my %CLASSPATH% be set to?
Thanks for any help.
Best answer by MikeLockwood
See attached doc when I put this in a few years ago.  Had same issue - solved by setting java path in the cmd window.
as in... what would the path be so I can just type the path into the command....
You can alternatively run below command first:
1. set CLASSPATH=%WT_HOME%\srclib\tool\Annotations.jar;%WT_HOME%\srclib\tool\AnnotationProcessing.jar;%CLASSPATH%
(Make sure your WT_HOME is set)
2.
javac -d %WT_HOME%/codebase ext/company/wvs/AfterEDRloader.java
(ext/company/wvs is where you stored your AfterEDRloader.java file)
I don't believe %WT_HOME% is set
I can just type in the path yes?  would i need quotations for the path?
22-Sapphire I
July 6, 2020
Thank ya sir!  I was able to set everything up but the stp file extension...
0 [main] ERROR com.ptc.windchill.structconf.StructConfManager - Extra unrecognized arguments: "stp"
was returned... it took pdf.
I had just a space between pdf and stp.. is that syntax no good?
22-Sapphire I
July 6, 2020
I forget which but requires .stp for Creo Parametric and .step for SolidWorks (or vice versa).
No matter how good the CS articles are I always find it necessary to create a complete document like that one. Wish I could sell them somehow 🙂
