變量下拉
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.8
流程中設置變量,需要下拉值,在某個審核的任務節點,填寫該變量(屬性),出現問題,按照下面的文章創建了對應的A類和_A類,以及RB文件,但是在執行命令時報錯了,也沒生成對應的ser文件。
https://www.ptc.com/en/support/article/CS36017?art_lang=zh-cn
    Catalina
    Community Manager
    Hi @陈南_13333632
    Thank you for your question!
    I’d like to recommend to bring more details and context to your initial inquiry. For example:
    • Are there any permission or path issues preventing the .ser file from being generated?
    • Is the workflow editor unable to locate the class due to missing entries in the resource bundle or incorrect classpath?
    Please add screenshot(s) to better understand what you are trying to do in your process.
    Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
    Here's what a good question for Windchill looks like.
    Thank you for your participation and please let me know if you need further assistance!
    Best regards,
    Catalina | PTC Community Manager
    HelesicPetr
    Hi @陈南_13333632
    You have to write the error and also I recommend to use an English error 😄
    PetrH
