VladimirNAnswer
Oct 23, 2021 12:24 PM UTC
"The Advanced Grids are available as standard widgets in the ThingWorx Platform for 8.5.X and later. ThingWorx 8.4.X and earlier uses Advanced Grids that are available as extensions in the PTC Software Download page: https://support.ptc.com/appserver/auth/it/esd/index.jsp . There may not be an upgrade for these extensions in later releases. It is recommended to use the standard widgets in the ThingWorx Platform 8.5.X and later".
Link: http://support.ptc.com/help/thingworx/platform/r9/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/AdvancedGrids.html#ID0E44X5
VladimirN24-Ruby IVAnswer
pshashipreetham
Oct 23, 2021 3:13 PM UTC
hi @VladimirN ,
Read all the articles shared by you, but what's the solution ?
previously 8.4 version was used and those 8.4 mashups have been imported to 9.2 version, now Advanced Gird (Configure Grid Columns Settings) are not working in 9.2, 8.4 advance grid extensions are also removed !!
but still this is same issue, should server to be restarted ?
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Support
Oct 28, 2021 6:40 PM UTC
Hi @pshashipreetham.
Please provide some detail around the issue.  What isn't working?  Are you getting any errors?
--Sharon
