6-Contributor
May 9, 2020 2:58 AM UTC
how to consume a stream from ODATA response
I have a Windchill ODATA End-point that streams(edm.stream) the representation of a document. Is there a code snippet to consume the stream from odata response.
barkoAnswer
May 11, 2020 1:42 PM UTC
I am not aware of an OOTB code snippet to consume the stream from the OData response.
barko16-PearlAnswer
Support
May 20, 2020 3:44 PM UTC
Hi @Swamy_Senthil.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.  If you still have questions, please let us know.
--Sharon
Support
Jun 2, 2020 9:04 PM UTC
Hi @Swamy_Senthil.
I have marked the Accepted Solution for your post.  If you disagree that it is the solution, please provide further information and I will remove it.
--Sharon
