Feb 18, 2025 4:47 PM UTC
How to get search to return latest released objects?
Hello Devs,
I'm new to Navigate and have created a custom task where I need the search to return only the latest released objects. However, it's currently fetching multiple released versions as well as objects in the Production Rework state.
As it's a custom task, I can't control the search using a saved search.
I tried using the following navigation criteria, but it didn’t work:
State eq 'Released'
Do I need to use a different navigation criteria, or is there an issue with this one? Could you provide a sample criteria to achieve the desired result?
Thank you in advance.
Mar 31, 2025 8:08 AM UTC
This sounds like critical functionality that you would expect of Navigate, so that shop floor staff are accurately opening up the latest Released data.
I know you can make Navigate searches use Saved Searches in Windchill, which gives you control for specifying Latest and specific Lifecycle States, but there must be a better way of specifying this inside of Thingworx- I'm not sure what it is though!
