Mar 22, 2016 1:29 PM UTC
Learn How Role Based Apps Can Help Connect More People to PTC Windchill
For those of you who were unable to join us on Thursday, March 10th, for the webcast, “PLM Access for All Stakeholders”, the recording is now available here. Watch Chris Bergquist, PTC PLM Solution Manager, demonstrate PTC Windchill 11’s new role-based apps and hear what questions were top of mind for your colleagues.
With role-based apps, stakeholders across all parts of the product’s lifecycle can easily and securely access product data at their point of need.
For instance, with the View Drawing app you can enter a part number and quickly bring up a drawing for that part. This allows you to easily get to the critical information that's communicated from design to manufacturing in one step.
With the View Part Structure app you can enter a part number for an assembly and get a 3-D image of that assembly coupled with the part structure that describes that assembly. Highlighting a row in the part structure will simultaneously highlight the appropriate elements in the 3D assembly. This is a fantastic way to quickly understand the status of a part number and how the parts fit together in the design. This can be critical information for those in the role of procurement, tooling, process planning and sourcing.
These are just a couple of examples of how role-based apps can extend the value of PLM throughout your organization. Watch the webcast to learn how you can use role-based apps to:
      • View documents
      • View part properties
      • View parts list
      • View design files
      • View and measure in 3D
Existing PTC Windchill customers should note that you can take advantage of these apps immediately. There's no need to upgrade your existing Windchill deployment. So you can dramatically expand the value of PLM information across the roles in your company with no barriers.
Watch the webcast to learn more.
Mar 22, 2016 4:13 PM UTC
I won't be able to watch it at work.  They don't allow video replay on our network.  I'll have to check it out somewhere else.
Is this something to be used through a browser or would we need to install a program on each computer?
lnakon5-Regular MemberAuthor
Mar 22, 2016 4:26 PM UTC
You can view it in a browser. Let us know if you run into any problems.
Mar 23, 2016 1:38 PM UTC
To clarify, is the app something to be installed on a clients computer or can the database be accessed through a browser.  Not if something needs to be installed to view the webcast.
TomU
Mar 23, 2016 1:58 PM UTC
It depends.  The apps themselves are purely web based (like Windchill is), but if you want to view the visualizations you still have to have Creo View installed locally (for the time being).
Mar 23, 2016 6:44 PM UTC
Ok.  I'm pretty sure that I saw that PTC planned to come out with a pure HTML5 Creo View.  So I assumed that to be the case and was hoping we didn't have to install it anymore.
TomU
Mar 23, 2016 6:47 PM UTC
They are, but it has not been released yet.  Sorry.
