Navigate - how to configure search to only return latest released objects
- 9 replies
- 9851 views
- Translate All
I'm struggling to configure Navigate to only return latest released objects, and hoping someone here knows a solution. I'm using a Saved Search in Windchill with the following criteria:
Iteration = Latest
Revision = Latest
State = Released
Running this search in Windchill with input of "*TEST*" returns 4 files all latest released which is correct. The same search in Navigate however, results in 7 files including some (not all) older versions of the 4 files. Expectations are that I get the same search results when using the exact same input and Saved Search between Windchill and Navigate.
What's odd is that, if I run a search in Navigate without any wildcards, using the exact Number or Name, then I get the correct result, the latest released file. Seems like older versions are included in the search result when using a wildcard character and/or when there's more than one file that matches criteria. I have attached pptx file that shows the setup and other search options that didn't work.
Any help is greatly appreciated!
