7-Bedrock
Apr 13, 2025 12:09 AM UTC
Things is not defined.
In an Expressions function: ExistentPTO in a Mashup X,
I have a need to evaluate the payload on a call to a route (from another project: ToolB).
response = Things["ToolB.v6DocMgmt"].getDocuments({
if (JSON.stringify(response)[value] == []) {
    output = "Not a good number";
} else output = <target mashup name>;
When viewing the mashup, i get this in the logs:
19:06:28 WARN - Evaluation of expression "ExistentPTO" Failed. Things is not defined
Can I NOT use Things within an Expression function? How do i refer to a Thing in another project?
    Ascherer17
    Apr 22, 2025 2:42 PM UTC
    Expressions are executed on the "client" side (the user's browser) meaning you only have access to Expression inputs that you feed in and some items that are part of the browser. Whereas Services (defined on a Thing) run on the actual Thingworx server, so they can access your Thingworx model.
    It sounds like you may want to create a Service to perform the desired function and call it from your mashup.
    Catalina
    Community Manager
    Apr 17, 2025 2:48 PM UTC
    Hi @Socka_HW
    Thank you for your question.
    Best regards,
    Catalina | PTC Community Manager
    Ascherer17
    Socka_HW7-BedrockAuthor
    7-Bedrock
    Oct 6, 2025 3:23 PM UTC
    I created a Service (with the desired functionality) and called it from my Mashup..
    All is well ...
    thank you.
