Emeritus
June 17, 2021
ThingWorx Navigate 9.2 Preview: "Report a Problem" & ThingWorx Flow
Coming soon! Targeted for end of June 2021, our next release features a new Contribute App to "Report a Problem" & modernized Windchill connectivity with ThingWorx Flow!
1. "Report a Problem" with the new ThingWorx Navigate Contribute App
Imagine you're doing some testing  on the shop floor and notice some fluid leaking near one of the shock's on your ATV. What do you do? Call your supervisor over? Go over to the Engineering office and let them know? Fill out a paper form that you drop off at the end of your shift? What if you could submit the Problem Report digitally right from where you are at your workstation? Eliminating the need for a manual/paper based process! That's exactly what's possible with ThingWorx Navigate's new "Report a Problem" App. Enable anyone in your organization to report an issue, regardless of where it's identified. Ease of reporting an issue across the enterprise contributes to improved product and process quality. Drive greater engagement in a critical step of the PLM Change process, start planning your upgrade to ThingWorx Navigate 9.2 now!
2. ThingWorx Flow Windchill Connector
With ThingWorx Navigate 9.2, we're introducing modernized connector technology using PTC’s ThingWorx Flow to enable Windchill connectivity to support the “Report a Problem” App. What does this mean for you? With installer and configuration enhancements, customers can deploy and run ThingWorx Flow and ThingWorx Navigate together seamlessly for modernized connectivity to Windchill and other 3rd party systems. With configurable data flows and a wide range of connectors available with ThingWorx Flow, your multi-system custom app use cases can be realized.
A lot to look forward to with ThingWorx Navigate 9.2! Stay tuned for the release announcement when the software is available for download at the end of June 2021.
Thanks!
Emily
