7-Bedrock
Tiles widget support for Change Notice attributes
How can I display Change Notice attributes in the Tiles widget?
It currently supports the WorkItem and ChangeRequest object types, but when I add a ChangeNotice, I get the following error:
Unable to execute service GetAvailableAttributes on PTC.WCAdapter: Failed to run getAvailableAttributes: There is no WindchillEntityProvider that supports type Id PTC.ChangeMgmt.ChangeNotice.
In the PTC.ComponentMetadata.GetDataTableEntries service, which displays the object types, I add PTC.ChangeMgmt.ChangeNotice objectType so that it displays the Name value.
But, when calling the PTC.WCAdapter.GetAvailableAttributes service to view the attributes available with PTC.ChangeMgmt.ChangeNotice, the error mentioned occurs.
What else is needed to use the objectType of PTC.ChangeMgmt.ChangeNotice? Do ThingWorx Navigate Components only support WorkItem and ChangeRequest?
