3-Newcomer
Jan 24, 2020 8:58 PM UTC
Using Dynamic Menu in Master Mashup with Contained Mashups. How to send mashup parameters.
I am currently using a Dynamic Menu which will generate items based off the logged in user options. I would like to send parameters to a contained mashup based on which menu item they select. How can we do this.
Support
Jan 28, 2020 8:03 PM UTC
Hi @farmerj1.
Could you provide more information about your use case?  What parameters are you sending to the contained mashup?
--Sharon
