Dec 15, 2023 2:32 PM UTC
What's new in Business Tailoring and WRS for Windchill 13.0.1
  • Oct 27, 2026 6:23 PM UTC
  • 0 replies
  • 1862 views
  • Translate All
Learn what’s new in Business Tailoring and WRS for Windchill 13.0.1, moderated by Jeff Zemsky of PTC.
Watch Guide
Overview
This 33:45 PTC/USER preview session, recorded on December 12, 2023, covers what is new in Windchill REST Services (WRS) 2.7, which ships with Windchill 13.0.1, and PTC's direction for Windchill+ customization. Hemant Shadra of PTC explains the WRS 2.7 changes (custom master attributes, zip download of content, and classifiable documents), and Greg of PTC previews the Code and Configuration Deployment (CCD) package, automated deployment to Windchill+, and the WReadE readiness tool. It is aimed at Windchill administrators, developers, and integrators who build on Windchill REST Services or maintain Windchill customizations. Jeff Zemsky of PTC moderates.
Chapters
This video has chapters, also available from the player menu.
  • 0:00 to 10:35: Welcome and session overview (PTC/USER preview)
  • 10:35 to 12:19: Windchill REST Services 2.7: supported Windchill releases
  • 12:19 to 14:13: WRS 2.7: updating custom master attributes via aliases
  • 14:13 to 16:40: WRS 2.7: download a content holder's files as a zip
  • 16:40 to 18:50: Break: rejoin tip for Teams display issues
  • 18:50 to 19:51: WRS 2.7: Document entity is now classifiable
  • 19:51 to 21:25: Windchill+ customization: standardization and modernization
  • 21:25 to 22:27: Code and Configuration Deployment (CCD) package
  • 22:27 to 23:10: Automated deployment to PTC-hosted Windchill+
  • 23:10 to 24:30: DevOps, supported APIs and the WReadE readiness tool
  • 24:30 to 26:43: PTC/USER 2024 Windchill sessions and UX labs
  • 26:43 to 28:49: Q&A: CCD for on-premise and the Windchill UI session
  • 28:49 to 30:15: Q&A: does the zip download cover a part's documents?
  • 30:15 to 32:29: Live tour: WRS 2.7 docs in the Windchill Help Center
  • 32:29 to 33:45: Q&A on pending renames and closing
Key Takeaways
  • Windchill REST Services 2.7 is included with Windchill 12.0.2.16, 12.1.2.7, 13.0.0.4, and 13.0.1.0. Windchill 13.0.1 was released in December 2023.
  • Windchill REST Services is bundled with Windchill CPS releases, and 2.7 is an incremental release: framework changes, domain changes, bug fixes, and maintenance updates.
  • WRS 2.7 adds an action to update custom attributes that you added to a master object, as long as they are exposed as alias attributes on the version object. Before 2.7, only out-of-the-box master attributes, such as unit of measure, name, and number, could be updated through WRS.
  • Because the master attribute change is in the WRS framework, it applies to every domain that uses the master and iteration pattern, not only Product Management.
  • WRS 2.7 adds an action that combines all the content of a content holder, primary and secondary, into one zip file and streams it to the caller. It targets content holders, so it applies to documents and CAD documents, not to most parts.
  • The Document entity in the WRS Document Management domain is now classifiable, with the same classification actions that were already available for parts.
  • The Windchill Help Center has a separate top-level section for Windchill REST Services, where the WRS 2.7 changes are documented.
Which Windchill releases include Windchill REST Services 2.7?
Windchill REST Services 2.7 is included with Windchill 12.0.2.16, 12.1.2.7, 13.0.0.4, and 13.0.1.0. PTC bundles the WRS module with Windchill CPS releases, so you get 2.7 by installing one of those releases rather than downloading it separately. Hemant Shadra describes 2.7 as an incremental release: it brings framework changes, changes in the Document Management and Product Management domains, and the usual bug fixes and maintenance updates.
Watch: 10:35 to 12:19 (release slide listing the four Windchill versions that ship WRS 2.7)
How do I update custom master attributes with Windchill REST Services 2.7?
In Windchill REST Services 2.7, you can update a custom attribute that lives on a master object by exposing it as an alias attribute on the version object and then using the new update action. Before 2.7, WRS could only update the out-of-the-box master attributes, such as unit of measure, name, and number, even though the same custom master attributes could be edited in the Windchill user interface. The change is in the WRS framework, so it works in every domain that uses the master and iteration pattern, for example parts in Product Management and documents in Document Management.
  1. Add the custom attribute to the master type: For example, a custom attribute on the part master.
  2. Expose it as an alias on the version type: Create an alias attribute on the versioned object that points to the master attribute.
  3. Update it through WRS 2.7: Call the new action on the version entity to change the master attribute value.
Watch: 12:19 to 14:13 (slide explaining the master and iteration pattern and the new alias-based update)
How can I download all the files on a Windchill document as one zip with Windchill REST Services?
Windchill REST Services 2.7 adds an action that takes all the content of a content holder, such as a document in the Document Management domain or a CAD document in the CAD Document Management domain, combines it into a zip file, and streams the zip to you. For a document, that means all its primary and secondary content. Hemant Shadra says customers asked for this to support use cases such as sending everything in a document to a supplier. Most parts are not content holders, so the action does not gather the documents related to a part (see the FAQ).
Watch: 14:13 to 16:40 (slide on the new zip download action and its supplier use case)
Can I classify Windchill documents through Windchill REST Services?
Yes. In Windchill REST Services 2.7, the Document entity in the Document Management domain is classifiable. The classification actions that were already available for the Part entity are now also available for documents.
Watch: 18:50 to 19:51 (Hemant Shadra adds the classifiable Document entity from the WRS 2.7 slide)
What is PTC's approach to Windchill+ customization?
PTC's approach to customization for Windchill+, its SaaS offering, is built on two themes: standardization and modernization of customization. Greg of PTC explains that the PTC/USER 2024 session would revisit this methodology and put more emphasis on what it means for on-premise customers. As presented on December 12, 2023, the slides were still being finalised, so this segment is a short preview rather than a detailed walkthrough.
Watch: 19:51 to 21:25 (opening slide on standardization and modernization of customization)
What is the Windchill Code and Configuration Deployment (CCD) package?
The Code and Configuration Deployment (CCD) package is a structured package for Windchill customization that brings management to code and configuration artifacts that are otherwise poorly managed, or not managed at all, on the back end of the application. PTC walked customers through the CCD package structure at PTC/USER 2023. As of December 12, 2023, PTC was investigating whether CCD could be supported for on-premise customers, and had no definitive answer.
Watch: 21:25 to 22:27 (slide showing the CCD package structure)
How do customizations get deployed to PTC-hosted Windchill+?
For Windchill+, you build a CCD package, run CCD and test the package in your test environment, and then deploy it to the PTC-hosted Windchill+ environment through an automated deployment process. Greg describes the automated deployment as the part of the story that was least developed in 2023 and where PTC had made the most progress. The aim is a release management process for customers, which he calls "DevOps out of the box". These were forward-looking statements as of December 12, 2023.
Watch: 22:27 to 23:10 (Greg outlines the package, test, and deploy flow)
How can I check whether my on-premise Windchill customizations meet the Windchill+ standard?
Use WReadE, the Windchill+ Readiness Diagnostic Extension, which PTC released as an enablement tool for on-premise customers who want to review the state of their implementation. It takes the custom artifacts in your implementation and shows which of them meet the Windchill+ standard and which exceed it. Greg also points on-premise customers to the difference between supported and unsupported APIs as a key implication of the Windchill+ customization standard.
Watch: 23:10 to 24:30 (Greg on supported APIs and the readiness tool)
Where is the Windchill REST Services 2.7 documentation?
The Windchill REST Services documentation is in the Windchill Help Center, in its own top-level Windchill REST Services section, where the 2.7 changes are listed. The Windchill 13.0.1 changes are in the What's New section of the 13.0.1 Help Center. In the recording, Jeff Zemsky opens the live Windchill 13.0.1 Help Center and navigates to the WRS 2.7 changes.
  1. Open the Windchill Help Center: Go to the Windchill Help Centers page and select your release.
  2. Find the Windchill REST Services section: It is a separate section at the top level.
  3. Select 2.7: The changes for the WRS 2.7 release are listed there.
Watch: 30:15 to 32:29 (live tour of the 13.0.1 Help Center and the WRS 2.7 section)
What Windchill sessions did PTC plan for PTC/USER 2024?
As presented on December 12, 2023, PTC planned PTC/USER 2024 sessions in January 2024 on UI, collaboration, smart platforms, CAD data management, quality and regulatory, customization and configuration management for Windchill and Windchill+, and integration strategies, plus Navigate. PTC also planned a set of UX labs covering Windchill, visualization, and Navigate, where attendees could give feedback on upcoming designs.
Watch: 24:30 to 26:43 (slide listing the planned PTC/USER sessions and UX labs)
Frequently Asked Questions
Q: Does the Windchill REST Services zip download collect all the documents related to a part?
A: No. The zip download targets content holders. In most cases a part is not a content holder, so the action does not gather the content of documents associated with the part. If an object such as a representation has content, it is a content holder and the action applies to it. For a document, the zip contains all its primary and secondary content. (answered at 28:56)
Q: Where can I find the documentation for the Windchill 13.0.1 and WRS 2.7 changes?
A: The Windchill 13.0.1 changes are in the 13.0.1 What's New and Help Center. The WRS changes are in the Windchill Help Center, in a separate Windchill REST Services section where you can select 2.7. (answered at 30:15)
Q: Do I need to install Windchill REST Services 2.7 separately?
A: The video describes WRS as a module that PTC bundles with Windchill CPS releases. WRS 2.7 is included with Windchill 12.0.2.16, 12.1.2.7, 13.0.0.4, and 13.0.1.0. (covered at 11:01)
Links & Resources
