Windchill PLM "Classification " Tips & Techniques Session Recording (West Coast)
  • April 27, 2026 at 7:32 PM
  • 4 replies
  • 39272 views
  • Translate All
Check out this video on Using Windchill "Classification" in Windchill from PTC Application Engineers
Presenters: Kevin Sergeant (Solution Consutlting, Principal) and Ryan Butcher (Solution Consulting, Fellow).
Original Date Presented: August 17, 2022
To dive deeper into the subject, check out Windchill Classification.
WEBCAST Q&A
Question from Erik:  What version of Windchill do you need to get classification search?
Answer:  Any version supports this capability.
WEBCAST Q&A
Question from JP:  Can the classification attributes shown on the Details tab of a WTPart be set to multiple columns like additional attributes?
Answer:  This would like need to be done through a customization.  Not sure of any other way to do it.
Question from JP: If I create multiple attributes on a bottom node and then decide I need to create a lower node, can i make that change?  How does it effect existing classified objects?
Answer:  You can add a new node under an existing leaf node.  Existing items stay classified at the original note until they are specifically moved.
Question from JP:  Do classification attributes only exist on the bottom node?  Asked another way, can i have attributes "mid node" that automatically get pushed down to lower nodes?
Answer:  They cascade down from high nodes.
WEBCAST Q&A
Question from Raghu: Does Windchill do "auto classification" based on object size, weight, etc.?  Goal:  to find (mechanical) objects smaller than xx and/or lighter than yy OR specify ranges.
Answer:  If those attributes are defined in the classification, they can be used to filter results  based on those using explicit values or ranges of values.
WEBCAST Q&A
Question from Kribakaran:  Are the any recommended approaches for Part Name Standardization?
Answer:  You can use rules to auto name the classified objects based on elements like attributes, strings that you enter, or even a mathematical function.
Use this link to learn more:
https://support.ptc.com/help/wnc/r12.0.2.0/en/?_gl=1*lymm33*_ga*MjA5MDAzODk1OS4xNjgzMTI5MDc1*_ga_1QBT6P6HR1*MTY4MzEyOTA3NS4xLjEuMTY4MzEyOTEzNS4wLjAuMA..*_ga_CBN5QVB9VJ*MTY4MzEyOTA3NS4xLjEuMTY4MzEyOTEzNS4wLjAuMA..#page/Windchill_Help_Center%2FWCClassReuseNodeAutoName.html
