3d modeling of pcb in creo
  • August 30, 2012
  • 9 replies
  • 7325 views
Hi all,
I have pcb emn and emp files opened in creo but i am un able to make a 3d model
the same which looked in the allegro
please help
thanks
Best answer by BrianMartin
Hi Raj...
Importing the components is done through the EMP file. The board itself (and the holes) are from the EMN file. Broad space claim is all that EMP file will really give you... usually just blocks of the approximate size and shape of your components.
However, if you want, you can get a really tremendous board layout with real detailed parts by going to www.simplifiedsolutionsinc.com
Try this tutorial... I think it's written for one of the Wildfire versions of Pro/E, but it has some great information that should help you:
http://www.simplifiedsolutionsinc.com/images/Steps_to_create_3D_PCBs_in_ProE.pdf
If you need help after checking out these resources, let me know. I've worked with the gentleman that owns Simplified Solutions and he's very good. He saw a need in the Pro/E market and filled it... now he's expanded to other CAD systems as well.
Hope this helps!
-Brian
Try edit definition of the import feature and see if you can do anything with the import doctor.
You might also try to get a different export file like STP.
thanks but this does not work
may be there is problem with importing from allegro to creo
so what is the right way to import from allegro to creo
Regards
Search this in your help files:
"About Using the Allegro Format"
The help files suggest there are limitations that you are probably seeing and require special attention.
Which version of software are you using?
