3DConnexion SpaceMouse
- April 27, 2018
- 1 reply
- 3695 views
Hi, I'm using 3DConnexion SpaceMouse Pro with ProE wF5 and I have no problems.
Now I'm passing to Creo 3 and I have a strange graphic problem: during the 3D rotation it remains a red dot on the screen (that is the center of rotation, as you rotate the visualization with the center mouse button pressed) and I have to make an additionary rotation with tha "standard" mouse to make disappear the red dot.
I have to set a "special" option to use the 3d mouse?
