48235 Add or remove centre line from circular dimensions once created.
  • October 12, 2012
  • 2 replies
  • 1379 views
When you create a diameter or radius dimension you have a tick box for draw centreline but once it is done you cant go back and change it in dimension properties.  Can a centreline tick box be added to the dimension properties box,  Document - CS66443 has a workaround of delete it and re-draw the dimension.
Great idea - you should add it to the Product Ideas section - between Polls and Photo Albums. I'd sure vote for it.
Thanks Greg, i have created as an idea so vote away 🙂
