77 MB Top Level Assembly and Drawing SLOWWWWW
  • January 29, 2015
  • 20 replies
  • 5930 views
PTC!!! I have a huge assembly open with drawing, help me speed this thing up. It takes 30 minutes to open on a high speed connection.
Best answer by ClintWalton
Hi Marty,
There are quite a few available documents discussing performance improvement settings for both large assemblies (assembly mode) and drawings containing large assemblies. Here is the best one to start with:
http://support.ptc.com/cs/cs_27/howto/vew1046/vew1046.htm
Use simplified reps.
Does the model have lots of complex geometry?
How many components are in the assembly?
Are all the files saved in the current version of Creo(Wildfire)?
Are you using a PDM system or native filing?
Marty,
We had similar issues years ago but have since upgraded to Windchill, creo2 and got new workstations so now are able to open very large models. I don't know if it's one thing or the combination that helped.
I just checked one of my large assemblies, 101MB with 823 objects. It opened in under a minute. Even bringing into a new workspace and opening direct from Windchill took less than 2 minutes.
Are you opening it direct from the server or is it stored on your machine? If from the server, can you save it to your machine and try opening it? If it opens a lot faster, it sounds like a network issue. If no difference, it's most likely your workstation or the model itself.
Simplified reps will help once you open the model but will not help the initial opening of the assembly.
Complex geometry, especially rounded surfaces will greatly slow down the regeneration but you will see this slowdown every time it regenerates.
How the parts are created (features used) and how they are constrained in an assembly all make a difference. You could try openning lower level sub-assemblies and parts to see if one or more are much slower than others.
Let us know how it goes.
Bill
We pull the license from the network, I copied it to my desktop on my computer an it still runs slow. We are a large company with large models. There has got to be a setting or something. I have done everything, I mean EVERYTHING. Everything you have told me I have done. I just don't think the program can handle all of this information. I am pulling the license off of the network.
You said you pulled the license from the server, can you download the assembly model and parts to your workstation so you don't open it across the network?
Marty,
Where you pull the license file will have zero impact on the performance. Where you run Creo from (network or local installation) will have almost zero impact on it's performance. Just to prove this, borrow a license. You can then physically disconnect your network cable and Creo will still run. See if you notice any change in performance. I'm pretty sure you won't.
Borrow a license? We are a big company I cannot be messing with the license
To borrow a license you just use a different shortcut to start up Creo. It's not hard or dangerous and shouldn't require help from IT or anyone else. Is Creo installed locally on your computer?
It's a floating license
You know, the assembly doesn't take long to open up, it's the 14 sheet drawing. It's to bad creo makes you open all of the sheets at once in tabs in one session.
You can create drawing configs that have all the views erased and just resume the views you are working on - this is handled by a drawing Representation.
See http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/detail/To_Configure_a_Drawing_Representation.html
and
See http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/detail/Default_Drawing_Representations.html
I see that, but man that sucks too. PTC just needs to make it faster then all my problems would be solved. ha Whole lot of up front configurations.
Hi Marty,
Ugh, this is still a lot of work PTC. but thanks for the info I will just make do.
