A rotating model in PDF?
  • March 22, 2013
  • 10 replies
  • 7705 views
Hello All:
I remember that we were able to export a rotatable model to a pdf for others to look at.
Is this something we can do with Creo Elements?
Deguza
Best answer by highway45
Yes, that's correct.
You can do a 3D-pdf, but only with an Acrobat Pro module.
2D- und 3D-Formate (Acrobat 9 Pro Extended, Adobe 3D Reviewer)
Die folgende Tabelle enthält 2D- und 3D-Dateiformate, die Adobe Acrobat 9 Pro Extended und Adobe 3D Reviewer-Software importieren kann. Weitere Hinweise zum Importieren und Exportieren von Dateien finden Sie in der Hilfe von Acrobat 9 Pro Extended und 3D Reviewer.
Format / Anwendung
Erweiterung
Version
3DXML
3DXML
Bis 3.0
ACIS
SAT, SAB
Bis 15
Adobe Acrobat 3D
PDF-Format
7, 8, 9
Autodesk 3D Studio
3DS
Autodesk AutoCAD
DWG, DWF, DXF
12, 13, 14, 2000-2008
Autodesk Inventor
IPT, IAM
Bis 12.x, 2008
CATIA Graphical Representation (CGR)
CGR
CoCreate OneSpace Designer
PKG, SDP, SDPC, SDW, SDWC, SDA,
SDAC, SDS, SDSC, SES, BDL
V3 bis V2007
COLLADA
DAE
Dassault CATIA V4
MODEL, DLV, EXP, SESSION
Bis V4.2.5
Dassault CATIA V5
CATDRAWING
2D
Dassault CATIA V5
CATPRODUCT, CATPART
Bis R18
Hewlett-Packard Graphics Library
HP, HGL, HPL, HPGL, PLT
Industry Foundation Classes
IFC
IFC2x3 and IFC2x2
Initial Graphics Exchange Specification (IGES)
IGS, IGES
5.1, 5.2, 5.3
JTOpen
JT
Bis 8.2
KMZ
KMZ
Lattice XVL
XV3, XV0
P-XVL
PRC
PRC, PRD
Alle Versionen
Pro/ENGINEER
PRT, XPR, ASM, XAS, NEU
V18.0 bis Wildfire 4
PTC CADDS
PD, _PD, CADDS
Versionen 4x/5 explizit
Siemens I-deas
MF1, ARC, UNV, PKG
Bis 13.x (NX 5)
Siemens NX
PRT
2D
Siemens NX
PRT
Bis NX 5
Siemens Parasolid
X_T, X_B
Bis 17
Siemens Solid Edge
ASM, PAR, PWD, PSM
V19, V20
SolidWorks
SLDASM, SLDPRT
Bis 2009
STEP Exchange
STP, STEP
AP 203, AP 214
Stereolithography
STL
Universal 3D
U3D
ECMA 1, ECMA 3
Virtual Reality Modeling Language (VRML) Worlds
WRL, VRML
V1.0, V2.0
Wavefront Object
OBJ
Nur Mesh
Deguza1-VisitorAuthor
Thank you Markus. I don't speak much German but Google translate came to the rescue.
If I understand correctly:
  • I cannot do it from the Creo Elements end.
  • I need Adobe Acrobat Pro and some of its extensions.
  • An "Adobe 3D Reviewer" is also needed.
Is what I wrote above correct?
All the best,
Deguza
highway4513-AquamarineAnswer
Arturo answer is correct, without extra module you are able to generate a 3D pdf from a model with creo element direct. I did it with the task agent on a big assembly. So as to do that you need the licence option PDF 3D.
After the generation I was able to open the pdf and to see the 3D model, rotate, translate... without any option.
Best regards
Florian,
Do you have licenses for the 3D PDF module? I attempted to turn on the "3D PDF & U3D" Data Interface module in Creo Elements Direct but received an error that "no licenses are available" because we don't have licenses for this. Next I attempted to create a 3D PDF of a part using Task Agent like you said you did but the task failed.
Dan
Hello Daniel,
I had one but now I don't have, you need to contact your PTC sales representative to ask for one.
Best Regards.
Florian
