adding different materials to parts of a model
I want to add Copper material to the cylinder and aluminium for the box below. But when I do, the same material gets applied to the entire object.
please help!!!
please help!!!
I think the requested functionality is available starting from Creo 7.0. You can create two bodies and assign different material to each body.
please help!!!
You will need to model it as 2 separate bodies in your part file as Martin shows. This can only be done in Creo 7 or newer.
If on an older version of Creo, you will need to model them as 2 separate part files and then assembly them together in an assembly file.
