Adding multiple dimensions in one dimension in Creo 2
What I'm trying to do is add the through hole and counter sink dimension information to the through hole dimension. I've tried using the "&" and "@" symbols but that didn't work. This is the information that I used:
Through hole dimension name: add1
Counter sink diameter name: add2
My text string looks like this: @D THRU, C'SINK &add2
This is what I get: .140 THRU, C'SINK &add2
If I shorten the "add2" to "d2" it get the thickness of my sheet metal part. Don't know what the connection is there.
Any help would be appreciated.
