Adding "no plot" layers in drafting
  • August 24, 2010
  • 1646 views
Can any one help me add "no print" layers in to a ProE Drawing. I want to use them as simple reminders
David,
Probably the simplest thing to do is create Notes in your drawing, put them on a Layer of their own (which you can even name NO-PLOT), hide the layer, do a Save Status so that the default is to have that layer hidden. You can even create a Mapkey to unhide that layer if you want to do it quickly.
David
