adding templates to an existed drawing
  • May 19, 2014
  • 811 views
Hello
I did an engineering drawing in Parametic witout adding any templates, but now i want to add to this existed File an template, how can i do that? If i want to open the template, a new sheet opens without my old drawing objects.
You should be able to right click on the screen, select "Sheet Setup", make sure show format is checked, then in the format drop down select browse, and you can browse to the templete you want.template.png
